kicks me out of gtr mode
Discussion in 'Bamboo GTR' started by map, Jun 2, 2020.
  1. map
    map Member
    I got my bamboo gtr a few days ago, and am running into an issue. I ride up grass hills, push the board a bit, and in GTR mode. When the boards battery runs down to about 75% the hand remote control vibrates and downgrades me from GTR to the less powerful PRO mode, and it won't allow me to upshift into GTR mode anymore. I turn off the board and remote, then start them again, and I am able to go right into GTR mode again, but now only after a couple minutes the problem will happen again, and again. Does anybody else have this problem? Also I have tried setting the PowerSave value to "off", this does not make any difference. Any help would be greatly appreciated, thanks in advance...
  2. Deckyon
    Deckyon Member
    Sounds like you are pushing it too hard. Grass and hill and whatever your weight is will cause the motors and electronics to overheat. This is what is causing you to get pushed back a level.
    Try carving more, test out on more level ground and see if it does the same thing.
    • Like Like x 3
  3. kim cheese
    kim cheese Member
    Still an issue? Are you a heavier person? The Evolve YTube video where Nick @~60kg vs. the media guy @~100kg might be interesting to you and provide some possible answers.
