Advice On New Electric Longboard Build
Discussion in 'General Eskate Chat' started by Huntercc742, Jun 3, 2017.
More threads by Huntercc742
  1. Huntercc742
    Huntercc742 Member
    First time Building an electric skateboard, so I would like to know what could be changed with the list below... Here is my parts list.
    Single motor mechanical kit DIY Electric Longboard - DIY Electric Skateboard ... nical-kit/
    (For ease of assembly. I don't want to scavenge around for the rights parts.)
    6364-213kv motor https://hobbyking.com/en_us/turnigy-aer ... motor.html
    (I believe I want to get a higher kv rated motor probably 260.)
    VESC speed controller DIY Electric Longboard - DIY Electric Skateboard ... board-esc/
    (I don't know if this is the best VESC for my setup)
    servo connector for VESC DIY Electric Longboard - DIY Electric Skateboard ... connector/
    2.4 ghz remote DIY Electric Longboard - DIY Electric Skateboard ... ontroller/
    6s 25c LiPo battery http://hobbyking.com/en_us/zippy-compa ... -pack.html
    (This battery doesn't have a BMS, so I will not be getting now)
    My first question is with the battery: The one I chose doesn't have a BMS, so I would like to get a good battery with a BMS that will work well with the motor I get.
    My second question is with the motor: should I get a 260 kv motor. I need it for semi-steep hills. If I do Imagine Ill need a different battery probably 8s.
    Besides that, any modifications or tips would be appreciated
